chimney for oil boiler
Al Letellier
Member Posts: 781
Most masonry chimneys are 8" square flue but can vary. If you're building a new one, it has to be sized to the connected venting load. Check code manuals or manuf. minimun flue sizes for the equipment you are using.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
1. What size diameter is the standard chimney?
2. What is the clearance requirement on the inside of the house?
thanks0 -
For
What size boiler? Clearance depends on manufacture.
Can you provide us with more info?
Andy Morgan
R. Morgan Mechanical, LLC0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
