Rad valve--open vs partially closed?
btc
Member Posts: 43
I have one radiator (furthest from boiler) that accumulates water [and subsequently bangs once heat gets 1/2 way across). Pitch is okay so suspected valve opening. Took valve apart--when fully "open" the gasket still blocks 1/2 of the opening into the rad. This is original equipment (Detroit valve) on one-pipe steam so it is a little perplexing-it seems to be designed to only leave 1/2 open into radiator....Riser to valve is 3/4", Valve is 1", iron radiator EDR is about 25 (11 sections, 3 column, 18" high.) Hoffman 40 vent. Boiler pressure low, believe steam relatively clean. Any ideas appreciated.
trying to heat a small bathroom
i have a small bathroom in basement (25 sq ft).how can i heat it?it can get pretty cold.i have a one pipe steam system in the basement for the house.can some one offer any options?
thanks0 -
It should open further than that
try some penetrating oil on the stem threads.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
You could use
a small radiator hung high on the wall to keep it above the waterline, or run a hot-water loop from the bottom of the boiler to a radiator or baseboard on the floor.
Consulting0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
- 17 Recall Announcements
