L&M
Paul_28
Member Posts: 113
When should either, L or M grade of copper pipe be used??
well
type L copper is generally used on domestic water system's and type m on the heat side of thing's..I/E the baseboard piping..The company I work for only use's type L that way no one get's it wrong..;)0 -
The old code use to be
in NJ that you had to use L copper for hot and cold water and M was for heat only. Now according to my plumbing buddies that has changed. So I am not much help but great question. Waiting to hear the boys answer.
I also heard it
from a plumber in a supply house . I'm not sure if the code is different from town to town , county , or what level , around here on LI .0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
