Taco 110 circulator
joe_6
joe_6 Member Posts: 23
Can the 110 circ.be mounted horizontal or just vertical.Thanks
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    You can mount it any direction you want...
    so long as the motor shaft is parallel with the gorund, and the oil cup on the bearing assembly is pointing up:-)
    You can accomplish this by pulling the four bolts that hold the B/A onto the volute and turning it so the oil port is pointed up.
    ME
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    110 circulator installation instructions
    Good morning
    Thank you for using Taco products. Attached is the installation instruction sheet for the 100 series circulators. The correct mounting orientation is the motor shaft parallel to the floor. However, the flow direction can be horizontal, or vertical, the pump doesn't care. You can index the casing 90 degrees to meet your system requirement. The motor must be horizontal to keep the lube oil from weeping out the oil fill ports located at the top of the motor. Taco, does offer vertical pumps including multistage types. Please visit www.taco-hvac.com for a complete list of all products.
    Joe Mattiello
    Technical Support Services
    Tel. 401-942-8000 X 484
    Fax. 401-942-2360
    joemat@taco-hvac.com
    Joe Mattiello
    Taco Comfort Solutions
  • Billy_3
    Billy_3 Member Posts: 42
    taco 110
    When is it neccassary to use a 110. I have never used one.
    Steamhead Member Posts: 18,205
    The 110
    is a very popular unit- it has a similar capacity to the B&G 100 circulator.
    It is best suited to jobs that don't have a lot of head (back-pressure) since it can only pump up to 10 feet or so. It has a capacity of about 30 GPM at a 3.5 foot head, which makes it a good choice for converting larger gravity systems of 900-1200 square feet EDR or so to forced circulation (see
    http://www.heatinghelp.com/newsletter.cfm?Id=125
    for more on this).
    As long as it's properly lubricated, the 110 will last a long time. I see many older units out there, still pumping. And it's backed by people like Joe Matiello, who hang out on the Wall!
    Consulting
