Sarco (from the Library)
Mike T., Swampeast MO
Member Posts: 6,928
"Presupposes a balanced system"
Since balance was difficult (then as now) they offered balancing valves to replace regular hand valve.
Note cost: $2.50 max
Note cost and shipping weight of plain reset valve & sensor: $150 minimum and 75 pounds minimum.
Is this why the idea died?
Still fascinated...
1943
HEIGHT of WW-II. Brass & iron going to shells and Shermans. LOTS of R&D, but devoted to war.
Approved by War Commission.
Why?
Because old Doc Jones could be more comfortable and burn less fuel!
- 167 Indoor-Air Quality
