\"HEINROHR \" THERMAX METRIC PEX RADIANT TUBING
CASEY F
CASEY F Member Posts: 1
HAS ANYONE HEARD OF THIS TUBING?? WE NEED FITTINGS TO FIX A 13 YR OLD HOUSE FULL OF THE STUFF. IT'S A GOOD QUALITY PIPE, O2 BARRIER AND SO FORTH, BUT FOR RE-MODEL PURPOSES, WE NEED FITTINGS TO ADAPT TO. COMPRESSION FITTINGS APPEAR TO BE EXACTLY LIKE WIRSBO BRAND , BUT IN METRIC SIZES. PEX DOESN'T QUITE HOLD. I.D. IS 13.5 MM O.D. IS 18 MM ANY HELP WILL BE GREATLY APPRECIATED. THANKS, CASEY
  • Tim Doran_2
    Tim Doran_2 Member Posts: 131
    Call Me
    Give me a call I may have some fittings that will work. Can you send me a sample? 800-321-4739
    Tim D.
  • Ken D.
    Ken D. Member Posts: 836
    HEINROHR
    Isn't that HotRod's brother?
