\"HEINROHR \" THERMAX METRIC PEX RADIANT TUBING
CASEY F
Member Posts: 1
HAS ANYONE HEARD OF THIS TUBING?? WE NEED FITTINGS TO FIX A 13 YR OLD HOUSE FULL OF THE STUFF. IT'S A GOOD QUALITY PIPE, O2 BARRIER AND SO FORTH, BUT FOR RE-MODEL PURPOSES, WE NEED FITTINGS TO ADAPT TO. COMPRESSION FITTINGS APPEAR TO BE EXACTLY LIKE WIRSBO BRAND , BUT IN METRIC SIZES. PEX DOESN'T QUITE HOLD. I.D. IS 13.5 MM O.D. IS 18 MM ANY HELP WILL BE GREATLY APPRECIATED. THANKS, CASEY
Call Me
Give me a call I may have some fittings that will work. Can you send me a sample? 800-321-4739
Tim D.0 -
HEINROHR
Isn't that HotRod's brother?0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
