Degree Days
Dave L_4
Dave L_4 Member Posts: 26
Does anyone have the web site for degree day history for different parts of the country?
thanks for your help.
DaveL
  • Bill Nye
    Bill Nye Member Posts: 221
    Hey Dave
    Try this
    http://www.cpc.ncep.noaa.gov/products/analysis_monitoring/cdus/degree_days/wsahddy.txt
    Try a search for Heating Degree day, I found a ton of stuff
  • Dave L_4
    Degree day
    good morning Bill,
    I'm trying to compare several years of data so I can accurately tell my customer how much oil they are saving. That site you just gave me does'nt do that, but thanks for the try. I know the feds have a list I just can't remember how I found it before.
    DaveL.
  • Harold
    Harold Member Posts: 249
    data
    Here is a source of the weather files used to run models. The stat files have degree days info.
    www.eere.energy.gov/buildings/energyplus/weatherdata.html
  • John@Reliable_9
    John@Reliable_9 Member Posts: 122
    Here's where I go everyday!
    www.weatherunderground.com Just follow the page and type in any city or town you want. Once current day is up look towards middle of page under your current data and you will see a history part, type in a date and you will get past heat,growing and cooling degree days and more! Hope this helps John@Reliable
  • Ed_13
    Ed_13 Member Posts: 164
    Degree Day info
    Give this a try. It does not give a daily running total, but it is monthly. Good luck
    Ed Carey
    http://www.erh.noaa.gov/box/dailystns.shtml
  • Dave L_4
    degree day
    thanks for all your help!!!!
    Dave L
  • S Ebels
    S Ebels Member Posts: 2,322
    Accuweather.com
    Has degree day data as well as a lot of other historical info on their site. Go to the main page and type in your zip. It will bring up your local area and from that you cn selsct from the menu there, what you want to see.
  • Ed_13
    Degree day sites
    Dave,
    How did you make out on DD information. I sent a site to you however, if in your search you found one that is better, please let us know so we can check it out.
    Regards,
    Ed Carey
  • Ed_13
    Degree day sites
    Dave,
    How did you make out on DD information? I sent a site to you however, if in your search you found one that is better, please let us know so we can check it out.
    Regards,
    Ed Carey
  • George Peteya
    George Peteya Member Posts: 34
  • Steve_35
    Steve_35 Member Posts: 545
    Degree Day site
    Here's the one I use. http://www.erh.noaa.gov/ Enter the city/state you want data on in the upper left corner. Then in the upper left corner just under the NORA symbol you'll see a city/state. Click on that. At the next screen select a city under "Historical Climate Data". From there it's pretty obvious. For our area they have data back to 1951.
  • John@Reliable_9
    Ed, check out ............
    the one I posted. Very easy to use ie: gets to the point quick! John@Reliable
