Degree Days
Dave L_4
Member Posts: 26
Does anyone have the web site for degree day history for different parts of the country?
thanks for your help.
DaveL
DaveL
Hey Dave
Try this
http://www.cpc.ncep.noaa.gov/products/analysis_monitoring/cdus/degree_days/wsahddy.txt
Try a search for Heating Degree day, I found a ton of stuff0 -
Degree day
good morning Bill,
I'm trying to compare several years of data so I can accurately tell my customer how much oil they are saving. That site you just gave me does'nt do that, but thanks for the try. I know the feds have a list I just can't remember how I found it before.
DaveL.
data
Here is a source of the weather files used to run models. The stat files have degree days info.
www.eere.energy.gov/buildings/energyplus/weatherdata.html0 -
Here's where I go everyday!
www.weatherunderground.com Just follow the page and type in any city or town you want. Once current day is up look towards middle of page under your current data and you will see a history part, type in a date and you will get past heat,growing and cooling degree days and more! Hope this helps John@Reliable0 -
Degree Day info
Give this a try. It does not give a daily running total, but it is monthly. Good luck
Ed Carey
http://www.erh.noaa.gov/box/dailystns.shtml0 -
degree day
thanks for all your help!!!!
Dave L0 -
Accuweather.com
Has degree day data as well as a lot of other historical info on their site. Go to the main page and type in your zip. It will bring up your local area and from that you cn selsct from the menu there, what you want to see.0 -
Degree day sites
Dave,
How did you make out on DD information. I sent a site to you however, if in your search you found one that is better, please let us know so we can check it out.
Regards,
Ed Carey0 -
Degree day sites
Dave,
How did you make out on DD information? I sent a site to you however, if in your search you found one that is better, please let us know so we can check it out.
Regards,
Ed Carey0 -
Degree Day site
Here's the one I use. http://www.erh.noaa.gov/ Enter the city/state you want data on in the upper left corner. Then in the upper left corner just under the NORA symbol you'll see a city/state. Click on that. At the next screen select a city under "Historical Climate Data". From there it's pretty obvious. For our area they have data back to 1951.0 -
Ed, check out ............
the one I posted. Very easy to use ie: gets to the point quick! John@Reliable0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
