Steam Pipe Question
Bud_14
Bud_14 Member Posts: 200
This question was posted by a contractor on my site, I told him to ask it here where they can better help out. Thanks for the help, I know him and he will very much appreciate it
Bud
They wanted to know what type of pipe dope one would use on 1 1/2" schd. 80 pipe, at 150 psi and 550 degrees F ? I did not want to post this at Sheet Metal Talk forum with concern for vering off the forums path. They will be looking I am sure this week end. If you could help it would be greatly appreciated. I am clueless!
  • SINKDOC
    SINKDOC Member Posts: 2
    pipe dope
    A compound used on steam systems called XPANDO.
  • bob young
    bob young Member Posts: 2,177
    HERCULES CHEMICAL, RECTORSEAL, S.O.S. PERMATEX ARE ALL SERIOUS PRODUCTS. ANY ONE OF THESE WILL WORK WELL .CHECK WITH FACTORY REP. IF VOTE OF CONFIDENCE IS REQUIRED.
  • Tony Conner
    Tony Conner Member Posts: 549
    The Most Important Thing To Do Is...
    ...read the manufacturer's info. Lots of thread sealants run out of gas at 300*F or 400*F. Some are only good up to 1-1/2" or 2" pipe. Some aren't recommended or approved for certain fluids. You can eliminate a LOT of problems right away by just reading the package.
  • Bud_14
    Thanks Much
    I'll send him here to the wall..I thought I emailed him the link..but I could have missed it..
    Bud
  • joe_17
    joe_17 Member Posts: 24
    gasoila softset
    Good on steam up to 600 degrees.Have used on steam up to 250 psi,which is about 450 degrees,works great.Happy pipe doping!
  • bob young
    you nailed that one JOE.
    I Found a can in my shop today. forgot all about that brand. good for 10,000 # 600 degree's pretty serious. soft-set w/ teflon
