Steam Pipe Question
Bud_14
Member Posts: 200
This question was posted by a contractor on my site, I told him to ask it here where they can better help out. Thanks for the help, I know him and he will very much appreciate it
Bud
They wanted to know what type of pipe dope one would use on 1 1/2" schd. 80 pipe, at 150 psi and 550 degrees F ? I did not want to post this at Sheet Metal Talk forum with concern for vering off the forums path. They will be looking I am sure this week end. If you could help it would be greatly appreciated. I am clueless!
Bud
pipe dope
A compound used on steam systems called XPANDO.0 -
HERCULES CHEMICAL, RECTORSEAL, S.O.S. PERMATEX ARE ALL SERIOUS PRODUCTS. ANY ONE OF THESE WILL WORK WELL .CHECK WITH FACTORY REP. IF VOTE OF CONFIDENCE IS REQUIRED.0 -
The Most Important Thing To Do Is...
...read the manufacturer's info. Lots of thread sealants run out of gas at 300*F or 400*F. Some are only good up to 1-1/2" or 2" pipe. Some aren't recommended or approved for certain fluids. You can eliminate a LOT of problems right away by just reading the package.0 -
Thanks Much
I'll send him here to the wall..I thought I emailed him the link..but I could have missed it..
Bud0 -
gasoila softset
Good on steam up to 600 degrees.Have used on steam up to 250 psi,which is about 450 degrees,works great.Happy pipe doping!0 -
you nailed that one JOE.
I Found a can in my shop today. forgot all about that brand. good for 10,000 # 600 degree's pretty serious. soft-set w/ teflon0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
