Grundfos Variable Speed Circulator Pumps
RonF
Member Posts: 6
Can you switch the pump speed when it is running? Or should the speed be switched when the pump is off.
Thanks
Thanks
thats what the variable speed controller is doing basically ,Al
Grundfos pumps
You can change the speed on our 3-speed UP 15 pumps while they are running.
Contact me if I can be of any further help.
Rich C.0 -
My original post should have been a more specific sorry. I have a UPS 15-58 FC0 -
Thanks!! I will give try it tonight.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
