Grundfos Variable Speed Circulator Pumps
RonF
Member Posts: 6
Can you switch the pump speed when it is running? Or should the speed be switched when the pump is off.
Thanks
Thanks
thats what the variable speed controller is doing basically ,Al
Grundfos pumps
You can change the speed on our 3-speed UP 15 pumps while they are running.
Contact me if I can be of any further help.
Rich C.0 -
My original post should have been a more specific sorry. I have a UPS 15-58 FC0 -
Thanks!! I will give try it tonight.0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
