Radiant cooling from KaRo.com
RonPR
Member Posts: 10
Has anyone heard of the Karo system for radiant cooling .
Yup.
check with Allen Bel.0 -
are you contemplating some space conditioning?
www.karosystmes.com is one mighty fine direction to head . were i in slightly warmer climates i'd lash up the space conditioning idea and soon all my neighbours would want it!:)0 -
Karo capillary tubes
These are one of three major European brands of polypropylene capillary tube mats. Capillary tube mats are used in literally hundreds of thousands of square meters worth of radiant heating/cooling systems in Germany alone. They are normally applied into plaster ceilings, on top of drywall ceilings, or integrated into suspended radiant ceiling panels (cassettes). The advantage that capillary tubes have is that you get a much more even surface temperature distribution. The polypropylene is NOT an oxygen barrier material, so if these capillary tubes are going to be used, they need to be separated from the metallic piping systems and central plant equipment by a heat exchanger. Normally in Europe, the whole piping distribution system that feeds the capillary tubes is also run in thermally welded polypropylene pipe, with stainless steel or all bronze valves and fittings.0 -
Karo
naturalcooling.com
capillary tubes approximately 1/16th inch in diameter, spaced about 3/8 inch apart
no oxygen diffusion barrier = no cast iron0 -
Rad cooling
Thank you guys for responding I AM IN CANADA and we still need cooling , we have been using unico hi-v system butwould like to switch to radiant has anyone done any residential projects in the US yet , we would like to know where and when ?0 -
Where in Canada?
I'm in Vancouver and have been involved in a number of radiant cooling applications, mainly larger institutional projects, but the physics are the same. Enermodal Engineering in Kitchener, Ontario are another possible source- they did a suspended radiant panel project (Green on the Grand in 1996) and more recently a radiant slab project (Earth Rangers Wildlife Centre). There are very few folks in North America who have got any kind of track record at radiant cooling applications. Dr. Mumma at Penn State has done some good research on radiant cooling panels and the folks at Arizona State University have done some test houses using radiant cooling coupled to heavy mass structures.0 -
radiant cooling
Hi Geoff I am in Calgary Alberta is the radiant cooling something to look at cost wise for residential instalations we do custom homes in the calgary area , what were the costs per square foot in our canadian peso, please feel free to email me directly or ill see your reply here Ron0 -
Your e-mail
Ron: your e-mail bounced so please advise how I can send something to you. Cheers, Geoff.0
- 167 Indoor-Air Quality
