Pressure Reducer, & tankless: Expansion Tank?
to have one put in . Pressure reducers usually do not let water flow through them backwards , so a good buildup of pressure will kick the relief valve open . Hey Phil , is this the job you were talking about a few weeks ago ?
  • Patchogue Phil_21
    Patchogue Phil_21 Member Posts: 6
    Gonna put a whole house pressure reducing valve on M.I.L. house (street pressure is more than 125 psi). The gas fired boiler has a 4 gpm tankless coil in it.
    Does this require an expansion tank?
    What size?
    There will be about 8 feet of 1/2" copper from the whole house reducer to the tankless coil.
    Phil
  • ed wallace
    ed wallace Member Posts: 1,612
  • John Abbott
    John Abbott Member Posts: 362
    Expansion tank
    For tankless coils we use a watts 150A water hammer arrester it is plenty big enough for the small volume contained in a tankless coil.
    John
  • Patchogue Phil_21
    Yep
    Same job, Ron. I knew/know that with a water heater tank you need an expansion tank. I just wasn't so sure for a tankless coil.
    Phil
  • Patchogue Phil_21
    hammer arrester
    Thanks John, for that tip. Do you have a favorite whole house pressure reducer? (Someone had recommended one a few weeks ago, but I mismember and cannot find that thread here. I didn't mark it.)
  • John Abbott
    Reducing valve
    > didn't mark it.)
  • John Abbott
    Reducing valve
    I use the Watts U5B
    John
  • Ray Landry
    Ray Landry Member Posts: 203
    Just make sure you use a potable water expansion tank...
    FYI: every water heater doesn't need a tank, only homes with PRV's, like stated above, the act like check vavles and don't allow expansion back into the street water line
  • I was just talking to a
    serviceman buddy of mine and he told me they keep going back on new boiler installs with a coil . The domestic relief valves keep popping , even on the highest setting . I don't know if each home had a backflow preventer or a pressure reducer . Would those little white Amtrol Mini-trols work good for a coil and excess pressure ?
