German printing press needs hot water (PAH)
Dave Yates (PAH)
Member Posts: 2,162
Ran into an interesting and captivating brain teaser yesterday. The printing press in question needs to have hot water (170 F) circulated through the rollers to cure an applied process that is added to the paper.
They're currently using a tube shell type heat exchanger with a number of three-phase elements. Lots of issues with the piping and pumping arrangement, which are causing cavitation and air lock-outs.
Once they dig up the old specs, it'll be time to determine how many Btu's are needed to maintain the 170 F. Short-cut is to cross over the watts to Btu's, but might be over kill.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Dave
We did just the opposite, we do work for a company that mills ink for different printing. They were using cold water from the main to cool the mills and dumping it. We installed a chiller and re-circulate the water.
Always interesting to see other companys process's.
Scott
- 167 Indoor-Air Quality
