I need the tool and nipples to rebuild Peerless radiators
Al in Portland
Member Posts: 4
I need help finding the tool and the nipples to rebuild Peerless 3 column radiators. Can anyone help?
Dan's book EDR
tells me that American Peerless Column Rads were assembled with threaded nipples.
I've been told that removing threaded nipples from old radiators is essentially an exercise in futility. Considering the effort that has been required to remove tapping plugs, I tend to agree. (I had to drill out the central portion of the plug and then VERY carefully use a Dremel tool to cut just until I reached the high points of the radiator threads in a few places. Hours and hours. Something I don't want to do again.)
You probably can find a spud wrench that will fit the nipples but I daresay that the chances of it working without just destroying the nipple lands is remote.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
