WM Ultra
Paul_28
Member Posts: 113
Is the Purge Valve in the correct location in the drawing? I think it should be moved to be between the Flow Check and the Isolation Valve. The purge water needs to move through the Check Valve in the direction intended. Yes NO ????? Thanks Paul
Yes but you need to put in an isolation valve right after your drain because the check valve gives a direction of flow and will only allow the water/air to move in the direction intended.0
- 167 Indoor-Air Quality
