WM Ultra
Paul_28
Member Posts: 113
Is the Purge Valve in the correct location in the drawing? I think it should be moved to be between the Flow Check and the Isolation Valve. The purge water needs to move through the Check Valve in the direction intended. Yes NO ????? Thanks Paul
Yes but you need to put in an isolation valve right after your drain because the check valve gives a direction of flow and will only allow the water/air to move in the direction intended.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
