Erie zone valve
amie
amie Member Posts: 2
I have 5 erie zone valves ( VT2313G12A02A)and I need to connect each one to individual thermostats which require 3 wires. I am now using thermostats which only require two wires and they work well, but the thermostats I want to use require 3 wires so I can remotely control the thermosats through my security system and the third wire is necessary for the common(?). the erie's, according to my hvac person, is designed for only two wires to be connected to the thermostat. Is there a way to configure the zone valves or thermostats so three wires are used. Somehow I need the common to create a loop or something like that.
Thanks
amie
  • Ken_8
    Ken_8 Member Posts: 1,640
    Would it not make more sense to
    leave the existing 'stats and ZV's alone and simply snag the signal on the "output" wires of the ZV?
    Don't quite understand what your attempting to do.
  • lchmb
    lchmb Member Posts: 2,997
    just a thought
    just a thought..but contact the maker of the tstat...sure they must have way's that they want them wired..
  • Art Pittaway
    Art Pittaway Member Posts: 230
    Do you need an end switch?
    The alarm system may need notification that there is a call for heat? Just a guess. Your Erie zone valves are a "Pop-Top" model so they are easy to change. If you want to look for actuator options go to www.invensysibs.com, Products, Erie, Literature, and all the instruction sheets and wiring is there.
