Pressure Problem
I just went to look at this boiler. the homeowner claims that the fourth floor is not getting sufficient heat and that one specific radiator is air bound. He also states that to get the fourth floor hot he not only has to bleed the specific radiator, he also has to manully feed the boiler through the fast-fill to bring up the boiler pressure. This boiler feeds a old gravity system which now has circulators and flowchecks on every zone. the system has no source of air elimination or seperation, except for auto vents on each radiator. HELP! PLEASE!
