shut off valves on cast iron radiators
jed
jed Member Posts: 2
I have a 85year old house with cast iron radiators, The valve on the radiators are leaking at the stem, is there a way to fix this problem without replacing the valve , if not how do you replace the valve without cutting pipe.
jed
  • jed
    jed Member Posts: 2
    leaking valve
    jed
  • Paul Mitchell
    Paul Mitchell Member Posts: 266
    valves
    the valves should have a union at the radiator. You can also try and tighten the packing nut which is the nut that goes around the stem.
  • tim smith
    tim smith Member Posts: 2,886
    packing
    Add teflon packing under the packing nut and snug down, usually works. Good luck. Good idea to release pressure off system when doing this.
  • David Efflandt
    David Efflandt Member Posts: 152
    Faucet packing graphite
    You can still do it the way it was done originally (which I did with a couple of mine). Ace Hardware has what they call "faucet packing graphite" which is a graphite impregnated rope. Loosen the packing nut and slide it up the stem, remove some old gunk if necessary, wrap some packing rope around the stem and tighten the packing nut over it. Don't tighten it too much, so you have room to just tighten it some more if it leaks in the future (usually only if the valve was operated, which should be rare).
