HELP ME FIND A TEXTBOOK FOR MY COMMUNITY COLLEGE CLASS
Fred Schreiner
Member Posts: 1
I TEACH A SIMPLE BEGINNER HYDRONICS CLASS AT THE LOCAL COMMUNITY COLLEGE HERE IN THE ROCHESTER, NY AREA. WE'VE BEEN USING A TEXTBOOK FOR SEVERAL YEARS THAT IS VERY HEAVY READING AND VERY DEEP INTO THEORY AND CALCULATION AND CORRECTING FOR DENSITY. MY CURLY-CUME FOCUSES MAINLY ON: HOT WATER HEATING, THE RELATIONSHIP BETWEEN BTUH, FLOW AND PRESSURE DROP, AND PUMP/AIR SEPERATOR/EXPANSION TANK/FILL VALVE LOCATION. I ALSO VERY BRIEFLY TOUCH ON STEAM SYSTEMS (that should be a semester in itself), AND CONTROLS. CAN ANYONE SUGGEST A GOOD BOOK OR EVEN A COUPLE OF BOOKS THAT WOULD SERVE THE PURPOSE OF A 15 WEEK COURSE AS DESCRIBED. I'M ALSO SENSITIVE TO COST ALTHOUGH THE CURRENT TEXTBOOK RETAILS TO THE STUDENT FOR ABOUT $85 SO THEY ARE ACCUSTOMED TO SPENDING SOME DOUGH.
Have you seen this book?
http://trainingroom.slantfin.com/courses.html
If the Guide 2000 book is something you are interested in, give me a call at Slant/Fin at 800 873 4346 ext 456
Noel0 -
not a text book
Dan Holohans book Pumping Away is not exactly a text book. But it is easy to read is in plain terms and covers A LOT of info on pumps, expansion tanks, fill valves, air separators and where to put them. It also tells you why to put them in particular spots.0 -
Help Fred,
It would be a great help if you go into edit and reduce all the caps to small letters.
Caps are considered loud language and are hard to read.
Thanks0
