wirsbo
rodr
Member Posts: 20
i need a a3060071 sensor and the supply houses dont stock the item.do any of you guys know of a substitution for this item that may be stocked?
thanks
Rod
thanks
Rod
Call Us ASAP
Call us as soon as you can and we will overnight one to you. 800-321-4739
Tim D.
Thanks Tim
i found that the supply houses are only stocking the tekmar 007 which should work to get this system running for tommorow0
- 167 Indoor-Air Quality
