wirsbo
rodr
rodr Member Posts: 20
i need a a3060071 sensor and the supply houses dont stock the item.do any of you guys know of a substitution for this item that may be stocked?
thanks
Rod
  • Tim Doran
    Tim Doran Member Posts: 208
    Call Us ASAP
    Call us as soon as you can and we will overnight one to you. 800-321-4739
    Tim D.
  • rodr
    Thanks Tim
    i found that the supply houses are only stocking the tekmar 007 which should work to get this system running for tommorow
