First job from Find Pro
Paul Mitchell
Member Posts: 266
Today we did our first job that we received from someone looking here on this site. Small one, we replace about 20' of return line, repiped the equalizer and hartford loop at the boiler. Also replaced the guts on one leaking radiator valve. We had one radiator not heating in an upstairs bedroom. (Part of the reason he called) Airvent good, valve ok, ended up that long ago someone replaced the riser with copper up the wall. In the floor where it goes from the outer wall, to the radiator valve the pitch is wrong. Tried raising it up a little but the fittings are not working with us. Might make it a little better. He is going to call us when he does a little remodel and we can get and change that riser.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=280&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Congratulations!
Thanks for the report, Paul.Retired and loving it.0 -
Way to go Paul........Find a .........
yields high-quality leads - very few lookie loos. Mad Dog
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Hey Murph...how is your add working
out for ya?????? Mad Dog
Hey Mad Dog,
He ain't answering .....so it must be working well. Chris0 -
Went on one today
Steam system with a few problem radiators.
What do you say Dan? "If the air can't get our, the steam can't get in".
I will be contacting a gentleman in Vermont that got us from this site.
Timber frame home with radiant, wood boiler, back-up boiler, etc.......
I like being the only one in the area Dan, so let's keep it that way!
Congrats Paul!
Mark H
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
