Burner choice for Buderus G115-34
DaveGateway
DaveGateway Member Posts: 568
I'm having a Buderus G115-34 installed and have been given a choice of burners, either Riello 40-F5 or a Beckett AFG. The boiler will be vented through a chimney with a 5" stainless steel liner as specified by Buderus.
Any preferences and/or opinions about 1) reliability, 2) performance. The contractor I'm using is equally capable of servicing both these burners.
  • Eric_10
    Eric_10 Member Posts: 17
    burner choice
    We have installed several with carlin burners and have had numerous problems. By far reillo seems to be the best match. Make sure flue temp is min. 350
  • S Ebels
    S Ebels Member Posts: 2,322
    Love
    the Riello F series. We've used F-3's through F-10's on Buderi and Viessmann and they just flat out work. We also specify them on all the Thermopride air scorchers that we install. We just dialed in one of those last Thursday, an F3 on a 90,000 btu unit. Zero smoke, not a trace, 13.7% CO2, 6ppm CO, 86.6% efficiency on the Testo. Nice. Real nice!!
  • clammy
    clammy Member Posts: 3,256
    g115 34
    Just did one early this week posted some photos .The company i work for doesn,t use any riellos they perfer the becketts AFi myself was doubtfully and wanted touse a riello but the beckett work flawless 13.5 on the co anda370 stack excellent draft and a great flame 140 psi pump pressure burned quite sweet i,ve also worked on the AF on a G215 but a 170 pump pressure tight hard core flame unlike the AFG quite a step up althuugh i've done a few AFG2 custumes on some mclean and was qiute surprised on there performace
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Personal preferrence
    is Riello. We purchased a Riello repair kit several years ago........we have NEVER taken a part out of it.
    When my customers sleep better, I do too.
    Mark H
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    I use either the Carlin or thr Riello....
    I have a f3 on my 115-21. It is a pretty loud burner... that riello roar, but do perform well. I am considering going to the Carlin later. I have used many carlin EZ w/ one minor issue. One major thing to look at and consider is who will be servicing it. What do they know best...kpc
  • Steve Eayrs
    Steve Eayrs Member Posts: 421
    Another Reillo fan here....
    when it comes to the Buderus. My opinion is they are quieter than msot other burners, and if want it real quiet get the BF model, w/ direct combustion air. You can get them without the post purge control, if you don't need it. They are VERY quiet.
    Steve
