Burner choice for Buderus G115-34
DaveGateway
Member Posts: 568
I'm having a Buderus G115-34 installed and have been given a choice of burners, either Riello 40-F5 or a Beckett AFG. The boiler will be vented through a chimney with a 5" stainless steel liner as specified by Buderus.
Any preferences and/or opinions about 1) reliability, 2) performance. The contractor I'm using is equally capable of servicing both these burners.
burner choice
We have installed several with carlin burners and have had numerous problems. By far reillo seems to be the best match. Make sure flue temp is min. 3500 -
Love
the Riello F series. We've used F-3's through F-10's on Buderi and Viessmann and they just flat out work. We also specify them on all the Thermopride air scorchers that we install. We just dialed in one of those last Thursday, an F3 on a 90,000 btu unit. Zero smoke, not a trace, 13.7% CO2, 6ppm CO, 86.6% efficiency on the Testo. Nice. Real nice!!0 -
g115 34
Just did one early this week posted some photos .The company i work for doesn,t use any riellos they perfer the becketts AFi myself was doubtfully and wanted touse a riello but the beckett work flawless 13.5 on the co anda370 stack excellent draft and a great flame 140 psi pump pressure burned quite sweet i,ve also worked on the AF on a G215 but a 170 pump pressure tight hard core flame unlike the AFG quite a step up althuugh i've done a few AFG2 custumes on some mclean and was qiute surprised on there performaceR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Personal preferrence
is Riello. We purchased a Riello repair kit several years ago........we have NEVER taken a part out of it.
When my customers sleep better, I do too.
Mark H
I use either the Carlin or thr Riello....
I have a f3 on my 115-21. It is a pretty loud burner... that riello roar, but do perform well. I am considering going to the Carlin later. I have used many carlin EZ w/ one minor issue. One major thing to look at and consider is who will be servicing it. What do they know best...kpc
Another Reillo fan here....
when it comes to the Buderus. My opinion is they are quieter than msot other burners, and if want it real quiet get the BF model, w/ direct combustion air. You can get them without the post purge control, if you don't need it. They are VERY quiet.
Steve0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
