Gas leak
ScottMP
ScottMP Member Posts: 5,882
and they kept smelling gas. They called the gas compnay who repaired a leak underground.
Still had the smell.
We got on the job and tested with our sniffer and found a rotten piece of pipe going thru the sill from the meter into the house.
Guess the Gas co. missed this. Yikes !
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Tom Meyer
    Tom Meyer Member Posts: 300
    Waste not, want not
    Hey Scott! It's only bad on ONE end. Flip it around and use the other end for a while.
    Now all you have to do is find out why that happened. Would hate to have the next time it fails cause any injuries.
    Tom Meyer
    Senior Designer/Trainer
    Precision Hydronics Corp
    www.precisionhydronics.com
  • Ball Valve
    Ball Valve Member Posts: 18
    like a tire
    That's only flat on the bottom. Good find, in my area it must be like yours not hard to "one up" the gas co.
  • GaryDidier
    GaryDidier Member Posts: 229
    Rotten pipe
    Scott, Thank God you took the time to find that leak. We could have been reading about that family in the papers.
    Good work.
    Gary from Granville
  • lchmb
    lchmb Member Posts: 2,997
    against concrete??
    was that laid on top of the concrete? something chewed that up pretty hard...
  • ScottMP
    That was installed
    Thru a tight hole in the wooden sill.
    Moisture held tight against the steel did that puppy in.
    Scott
  • pperkins
    pperkins Member Posts: 18
    plum who installed it???nevermind the gas co!
    How about plum who installed gas piping???The gas co is only liable for meter and service to street main.What are we, the gas police for plums???
