Gas leak
ScottMP
Member Posts: 5,882
and they kept smelling gas. They called the gas compnay who repaired a leak underground.
Still had the smell.
We got on the job and tested with our sniffer and found a rotten piece of pipe going thru the sill from the meter into the house.
Guess the Gas co. missed this. Yikes !
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Scott
Waste not, want not
Hey Scott! It's only bad on ONE end. Flip it around and use the other end for a while.
Now all you have to do is find out why that happened. Would hate to have the next time it fails cause any injuries.
Tom Meyer
Senior Designer/Trainer
Precision Hydronics Corp
www.precisionhydronics.com0 -
like a tire
That's only flat on the bottom. Good find, in my area it must be like yours not hard to "one up" the gas co.0 -
Rotten pipe
Scott, Thank God you took the time to find that leak. We could have been reading about that family in the papers.
Good work.
Gary from Granville0 -
against concrete??
was that laid on top of the concrete? something chewed that up pretty hard...0 -
That was installed
Thru a tight hole in the wooden sill.
Moisture held tight against the steel did that puppy in.
Scott
plum who installed it???nevermind the gas co!
How about plum who installed gas piping???The gas co is only liable for meter and service to street main.What are we, the gas police for plums???0
- 167 Indoor-Air Quality
