Honeywell C7013A Flame Detector
Susan McCarthy
Member Posts: 2
The C7013A Flame Detector for 7800 Series Controls.
I would like to know if honeywell is still manufacturing this flame detector and if not, what product have they put on the market to replace it?
Sorry
This part is long gone. As of June 2002. You either got to provide the 4 digit trail #, and maybe check around on line, or contact Honeywell. The main # for HW is 1-800-468-1502.. follow the promps. Sorry Bobby O0 -
Robert is right...
That control is obsolete and discontinued. There is no direct replacement. If you'll tell me where you are located, I will try to get you a local Honeywell FlameSafeguard Authorized distributor to suggest a replacement.. This type of product is only available from certain qualified and trained distributors.0 -
We need the C7013A1003 because it was spec'd to us. Now we've been told that we can use the C7962B1002 sensor and adaptor in it's place with no other modifications. We are just trying to make sure that this is OK.0 -
If it was an authorized Honeywell FlameSafeguard rep...
or distributor who told you that, then you should be OK. I really can't comment, that's a specialized market that I have little involvement in. You also could go to www.customer.honeywell.com and follow the prompts to the commercial Flame Safeguard website. I can find you a rep's name if you'll tell me where you are located.0
- 120 Geothermal
