Honeywell C7013A Flame Detector
The C7013A Flame Detector for 7800 Series Controls.
I would like to know if honeywell is still manufacturing this flame detector and if not, what product have they put on the market to replace it?
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    Sorry
    This part is long gone. As of June 2002. You either got to provide the 4 digit trail #, and maybe check around on line, or contact Honeywell. The main # for HW is 1-800-468-1502.. follow the promps. Sorry Bobby O
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    Robert is right...
    That control is obsolete and discontinued. There is no direct replacement. If you'll tell me where you are located, I will try to get you a local Honeywell FlameSafeguard Authorized distributor to suggest a replacement.. This type of product is only available from certain qualified and trained distributors.
  • Susan McCarthy
    Susan McCarthy Member Posts: 2
    We need the C7013A1003 because it was spec'd to us. Now we've been told that we can use the C7962B1002 sensor and adaptor in it's place with no other modifications. We are just trying to make sure that this is OK.
  • BillW@honeywell
    If it was an authorized Honeywell FlameSafeguard rep...
    or distributor who told you that, then you should be OK. I really can't comment, that's a specialized market that I have little involvement in. You also could go to www.customer.honeywell.com and follow the prompts to the commercial Flame Safeguard website. I can find you a rep's name if you'll tell me where you are located.
