spiro vent questiom
S Davis
S Davis Member Posts: 491
That is all I use on new installs and I don't have any air problems, I think they work very well as long as your near boiler piping is done correctly.
S Davis
  • sam_7
    sam_7 Member Posts: 3
    spiro vent questiom
    Are these spiro vents any good?
    Are ther other styles like that to use .
    I do not want an air scoop on my boiler.....
  • Tony_8
    Tony_8 Member Posts: 608
    absolutely
    I use them ALL the time. There are others making similar products also. Massive improvement in air elimination.
  • sam_7
    Is there a direction of flow on those?
  • Tony_8
    either way
    and the vent seal is dry, unlike a float vent which is wet, and we know how long those last :)
  • Steve Eayrs
    Steve Eayrs Member Posts: 421
    Just curious why you don't want an air scoop.?
    We still use them a lot and sometie on the bigger ones we install a spirotop (1/2") in the top of it.
    Have you had problems with air scoops.?
    Steve
  • hr
    hr Member Posts: 6,106
    Wish they had a sweat version :)
    and they are a bugger to clean the top end. But they do perform very well.
    Make sure your ph is on. I have seen the wire cage inside, from agressive fluid attack, unwind and pieces get into the circs.
    hot rod
  • Floyd_5
    Floyd_5 Member Posts: 418
    You got to hold it over....
    your head so that little wre hangs striaght down...then get that little ity bity wire to find the hole...:-)
    For me....the way they purge a system is awessome!!!
    The Spirovent and the Vortech seem to work pretty much equally great. Just recently started up a system with 8,000 ft of tubing and ran nary a drop of water to the drain. Purged that tubing clean in no time!!!! Of course the way the system is piped is critcal also, so it can be purge effectively.
    Floyd
  • Brian_19
    Brian_19 Member Posts: 115
    Spirovent
    Every job big or small gets one. Better than other brands that use a float vent on top to vent out air.
  • Tom Simensen
    Tom Simensen Member Posts: 74
    Bell & Gossett
    B & G's new sweat air separators are second to none and are very reasonably priced.
