Gyp-crete vs concrete overpour?
Martin_2
Martin_2 Member Posts: 1
We are installing radiant (hydronic) floor heat over an exisiting concrete slab. We are putting down 2x4 sleepers shimmed to level the floor. We then will fill the spaces between the sleepers with either gyp-crete on concrete. What are the advantages in this kind of an application using gypcrete over a regular concrete?
Also, any recommendations for gypcrete contractors in northern NJ?
