Lime........ I learn something new everyday
John Ruhnke1
Member Posts: 154
Can Lime in cement hurt copper pipes?
I always thought so. I never installed a copper radiant system so I never had the need to research the answer. I just assumed what I heard through the grape vine was true.
Chech out http://www.heatinghelp.com/newsletter.cfm?Id=145 for the answer.
What do they say when you assume something is true? You make an **** out of you and me.
Thanks Dan,
JR
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=96&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Thanks Dan,
JR
lime and fly ash
either one is bad -
fly ash - (acid) eats the pipe,
lime - (base) corodes it,
together in a perfect mix, balanced PH, (never happens of course) it would be ok
i dont trust any truck deliverd ready mixed stuff,
mix your own water block slicone QUICKREET, if you must bury metal pipe, otherwise sleave'n'seal it
if i have to run a galvinized electric pipe underground
i put it in pvc, and that inside cast iron waste line,
this ways the neither the rats nor the elements can get to it - what can i say, "murphy's got me the the short and curlies"0 -
Another common component
in concrete is GBFS (ground blast furnace slag) and CCB (coal combustion by products) These are the "unknowns when mixing copper and 'crete.
Type F flyash is generally Eastern coals byproducts with the higher sulfur content, which when mixed with moisture may attack copper. Type C is Western coal CCB's.
According to the director of the Redi Mix Concrete Association, from his RPA seminar several years ago.
Flyash is a good thing, finishers around here will add additional flyash to the mix for an improved finish-ability, especially in summer months. Readily available at low cost from all the coal fired power plants country wide.
hot rod
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
