lawsuits
GaryDidier
GaryDidier Member Posts: 229
These are mostly bogus or distorted stories, but if you apply the concept of the Mcdonalds suit to what we do for a living it becomes food for thought. Aren't many of the copper pipes on heat supply systems hot enough to cause severe burns. What about the pressure relief valves we all see with no or improper down piping? What about all the free advice given on this site? Can this be fodder for a lawsuit? Can you be held responsible for advice to a novice or homeowner who tries to save money by attempting their own repairs or installs? Just some pre workday thoughts.
Gary from Granville
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Hasn't happened
    in the seven years that the Wall has been up, Gary.
    Retired and loving it.
  • yes but
    Lets face it...it only takes 1...with a greedy lawyer.
    Nothing is your own fault...there is always SOMEONE you can blame..right? (check with your lawyer...he'll agree)
    (being facecious)
    Mike
  • DanHolohan
    Yikes!
    I'm going to go hide under the bed. ;-)
  • Dave DeFord
    Dave DeFord Member Posts: 119
    You might also want to check..
    On the liability you have for free advice. I believe that it is generally none. No consideration, no contract thus no liability. Check with your mouthpiece but, I believe that's the way it is.
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    There is no liability coverage for
    passing on information, FACT!
    It's not considered a good deed, it's considered 'professional conduct' in the eyes of the courts. Remember that in liability law 'no good deed goes unpunished'.
    In addition there is the copyright issue and once it's posted here it's copyrighted to the owner (Dan).
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    common claim
    over on alt.hvac the claim of liability for, and risk of being sued over, advice given to "homemoaners" is commonly given as an excuse for not doing so.
    However, I have yet to see anyone there provide an actual case where it's happened.
    Mark
