Staple up question
Do you normally run staple-up tubing under closets and cabinets, or just under actual living space?
Secondly, I have seen posts saying that the extruded transfer plates are good but not the thin aluminum type - what are some brand names of the good ones?
Thanks!
valve
  • Staple -up
    Normally not under closets & cabinets. Why heat under there?
    The best plates "I've heard" are made by Dale piccard. Wirsbo sells a good plate system that I've worked with. I think it's based on Dale's design though. Stay away from the thin u-type plates. Been there-done that.
    Gary
  • hr
    hr Member Posts: 6,106
    Some closets
    if they are on outside walls they will need some heat. Especially large walk ins!
    Maybe just 1 loop through smaller ones. Actually I like to locate the manifolds in closets. A nice seldom seen location and it bleeds a small amount of heat into the space.
    Generally not under cabinets, although I like to run a single loop under any cabinet that has plumbing running up through it, on outside walls. That's a common freeze up location :) Bathroom cabinets turn into towel warmers with some radiant under them. Don't try it in kitchen cabinets that store food, however.
    So the correct answer is, it depends!
    hot rod
