Staple up question
Fetzervalve
Member Posts: 7
Do you normally run staple-up tubing under closets and cabinets, or just under actual living space?
Secondly, I have seen posts saying that the extruded transfer plates are good but not the thin aluminum type - what are some brand names of the good ones?
Thanks!
valve
Thanks!
valve
Staple -up
Normally not under closets & cabinets. Why heat under there?
The best plates "I've heard" are made by Dale piccard. Wirsbo sells a good plate system that I've worked with. I think it's based on Dale's design though. Stay away from the thin u-type plates. Been there-done that.
Gary
Some closets
if they are on outside walls they will need some heat. Especially large walk ins!
Maybe just 1 loop through smaller ones. Actually I like to locate the manifolds in closets. A nice seldom seen location and it bleeds a small amount of heat into the space.
Generally not under cabinets, although I like to run a single loop under any cabinet that has plumbing running up through it, on outside walls. That's a common freeze up location
Bathroom cabinets turn into towel warmers with some radiant under them. Don't try it in kitchen cabinets that store food, however.
So the correct answer is, it depends!
hot rod
- 167 Indoor-Air Quality
