Rigid Pro-Press on baseboard copper
Ray Landry
Ray Landry Member Posts: 203
Can you use the pro press tool on baseboard copper? From my own experiance in taking apart joints after pressing, it never seems to crimp the actual copper at all, just the fitting itself, so my gut is telling me yes, but I'm cuirious if the thin walled copper used on baseboard wouldn't agree with the crimping method used in the pro press system. Any input is appreciated...
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    If its normal.....
    sized (1/2-3/4) pipe, I don't see a problem. Like you said,pipe size is pipe size. The jaw of the tool can't crush any more than the top going together.
    I've used it on a couple of freeze-ups this winter with no problems. The other advantage is when you just can't get the water to stop,no worries about it rolling back when the solder is ready to be put in the joint. Chris
  • Justin Gavin
    Justin Gavin Member Posts: 129
    We used it alot
    We use it alot for Baseboard on small loops. On long loops or multi-story use a vent elbow for bleeding in the future. I havn't had a leak yet and we have been using it since September.
    Good Luck,
    Justin
