Boiler re-pipe finished
Wayco Wayne_2
Wayco Wayne_2 Member Posts: 2,479
made in my garage weeks ago. I finally got to finish the job. Works great. I used a Wirsbo 311 boiler control, (same as Tekmar 364) The mixing loop runs an old cast iron radiators left over from a gravity system once upon a time. I have the top temp down to 130 and the t/stat is still satifying even through those low temps we've had over the last 3 weeks. I just pu on an indoor feedback sesor so the reset curve can take care of itself. The other zones are and indirect and 2 high temp loops. One for the basement and one for a sun porch, both run off zone valves that open and activate the high temp part of the boiler control. The customer should save a lot of money and is already way more comfortable now that his big rads aren't overshooting the tstat anymore. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
