Boiler re-pipe finished
Wayco Wayne_2
Member Posts: 2,479
made in my garage weeks ago. I finally got to finish the job. Works great. I used a Wirsbo 311 boiler control, (same as Tekmar 364) The mixing loop runs an old cast iron radiators left over from a gravity system once upon a time. I have the top temp down to 130 and the t/stat is still satifying even through those low temps we've had over the last 3 weeks. I just pu on an indoor feedback sesor so the reset curve can take care of itself. The other zones are and indirect and 2 high temp loops. One for the basement and one for a sun porch, both run off zone valves that open and activate the high temp part of the boiler control. The customer should save a lot of money and is already way more comfortable now that his big rads aren't overshooting the tstat anymore. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Looks great....! I'm assuming your indirect is ran with priority....Your Primary / Secondary is very clear. Trying to learn as much as I can for an upcoming installation. A picture speaks a 1000 words.0 -
i like the insulation.what is it?
rod0 -
The insulation
is just fiberglass with a white jacket. The elbows are plastic pre-formed to cover fibergalss wrapped ells. It's basically commercial pipe insulation. S'not cheap either. WW
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Nice!
One question, what is it venting into?
Any liner in that chimney?
Mark H
Sharp eye Mark
The chimney needs a liner. The customer knows this is so. The boiler is about 25 years old and has induced draft. I don't think the codes required them back when it was installed. He is weighing the choice of a new boiler, (maybe a munchkin?) But he is out of money for now. Now that the boiler is running at lower temps on reset, it becomes more critical that a choice be made soon. WW
CO
HOW BOUT A NICE CO DETECTOR?? Nice job.. boc0
- 114 Geothermal
