Pressure/Temp. gauge
joe_17
joe_17 Member Posts: 24
What kind of pressure and temperature gauges do you guys use on all these multi-zone systems.Do you use a combination temp./press. gauge,or just temp. gauge.What is the brand name and how long is the stem.A closeup picture would be greatly appreciated.Thanks.
  • Pat_12
    Pat_12 Member Posts: 27
    I am also interested in a high quality temp/pressure gauge. I am not happy with the quality of gauges that are packaged with most boilers. I am also interested in some temperature only gauges. These gauges will be used to monitor each zones return temperature (delta T). Please let me know what gauges you have had success with, and sources to purchase gauges. Any suggestions would be greatly appreciated.
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Here's a place that's been recomended by others before
    www.gaugestore.com
    sells all sorts of gauges.
  • hr
    hr Member Posts: 6,106
    If you want
    high quality, I've found it is better to use seperate pressure and temperature gauges.
    I have yet to find high quality tridcators.
    Most home ownwers have a hard time reading dual gauges, when asked over the phone :)
    hot rod
