Pressure/Temp. gauge
joe_17
Member Posts: 24
What kind of pressure and temperature gauges do you guys use on all these multi-zone systems.Do you use a combination temp./press. gauge,or just temp. gauge.What is the brand name and how long is the stem.A closeup picture would be greatly appreciated.Thanks.
I am also interested in a high quality temp/pressure gauge. I am not happy with the quality of gauges that are packaged with most boilers. I am also interested in some temperature only gauges. These gauges will be used to monitor each zones return temperature (delta T). Please let me know what gauges you have had success with, and sources to purchase gauges. Any suggestions would be greatly appreciated.0 -
Here's a place that's been recomended by others before
www.gaugestore.com
sells all sorts of gauges.0 -
If you want
high quality, I've found it is better to use seperate pressure and temperature gauges.
I have yet to find high quality tridcators.
Most home ownwers have a hard time reading dual gauges, when asked over the phone
hot rod
- 125 Chimneys & Flues
