hydronic and fhw basebord
bb_2
bb_2 Member Posts: 1
I am putting in a system and wondered if I could put fhw baseboard in bottom floor and hydronic on top of floor on second floor- high volume ceilings on second floor - first floor 8 ft ceiling. Thanks
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    Could you define...
    hydronic...fhw baseboard is a form of hydronics...you can pretty much do whatever as far as zoning...do the heat loss for eash room/floor and you should be fine...kpc
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
  • Al Letellier
    Al Letellier Member Posts: 781
    \"hydronics\"
    That's the beauty of hydronic heating. Sized right and installed properly, you can mix and match any of the many varieties of "hydronic" heating.
  • Tom Meyer
    Tom Meyer Member Posts: 300
    Mix and Match
    Sure, you can mix and match hydronic delivery types. Baseboard, in slab, sandwich, engineered board, ceiling systems, staple up, etc.
    One concern would be the water temperature requirements for the type of delivery method. For example, depending on the heat load of each of the zones, to have a 110 deg requirement for the tube in slab, and 180 deg for the baseboard. Decide what's the best for your lifestyle, most efficient and most economical.
    Tom Meyer
    Senior Designer/Trainer
    Precision Hydronics Corp
    www.precisionhydronics.com
