new style water heater
Nick_10
Member Posts: 1
I have installed a new style water heater and the pilot goes out several times a day. It will not stay lit. I replaced the unit, but the problem continues. Any one have any ideas?
is the size the same?
is the btu input the same? is the gas line sized properly? Is the vent blocked? kpc
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Combustion air adequate?
These things don't just "happen". There is usually a reason. Excess draft, inadequate combustion air, mechanically induced negative air pressure, gas line exposed to sun shine...
ME0 -
Did it get dropped hard....
During shipping or istallation? Have you taken a thermocouple reading and confirmed it to be acceptable? If the pilot flame isn't hitting enough of the prover,(did it get bumped out of place in shipping or installation) it will not be able to hold the pilot circut open . Just a thought. Chris0 -
where is ...
it installed? Is it in a closet? Is it in a laundry room next to a furnace? Is it in a basement next to a hot air furnace.
This is going to be a common problem with the new heaters. Many things in the house can cause this. A bit more info will help.
Need more info....What was there v whats there now? Gut feeling based on post..... GAS PRESSURE. Is the new unit AO SMITH atmosphereic direct vent?? Had a few dooseys with those & intermitent pilot outage... BOC0
- 167 Indoor-Air Quality
