Automag zone valve
Plumb
Plumb Member Posts: 6
Looking for the company for replacement zone valves. Last address I have is Jessup PA. 18434. Is there a substitute to replace this zone valve. There are 6 valves on the system.
  • Dale
    Dale Member Posts: 1,317
    phone
    800-451-2002 KCI industries 1111 hill street Jessup PA, good valve, they are normally open instead of the usual normally closed. Also they use a diode so they are sort of DC, you need a 3 wire stat if no relay is used.
  • Plumb
    thank you
