Automag zone valve
Plumb
Member Posts: 6
Looking for the company for replacement zone valves. Last address I have is Jessup PA. 18434. Is there a substitute to replace this zone valve. There are 6 valves on the system.
phone
800-451-2002 KCI industries 1111 hill street Jessup PA, good valve, they are normally open instead of the usual normally closed. Also they use a diode so they are sort of DC, you need a 3 wire stat if no relay is used.0 -
thank you0
- 125 Chimneys & Flues
- 120 Geothermal
