heated shower and liner question
rodr
rodr Member Posts: 20
I am using transfer plates with tubing in the walls and floor.The granit installer indicated he was using a liner for the floor and wanted to use tarpaper on the walls behind the cement board to protect against moisture.Should i be concerned with the use of tarpaper?Have any of you guys seen how the showers are constructed?Also do you think i need to be concerned with the liner and the heated floor?
thanks
Rod
