short-cycling boiler
ross
Member Posts: 37
I know of a steam boiler that short-cycles pretty badly. I believe it is because the boiler is about twice as big as the connected load. As I recall, it is a Smith cast iron sectional with a Powerflame burner. This is a housing complex with around 16 homes. The boiler is in operation when the outside air gets below a set temp. A few years ago they tried to lower the heating bills by putting in a timing device that allows them to have the boiler be "off" for designated time periods. I don't think that this has really helped much... they end up overheating their spaces when it is on so they will be comfortable during the off times. I was thinking they could have the burner adjusted to a lower setting to try to get more even operation. How feasible is this and what kind of problems could arise by doing this?
Find A PROFESSIONAL
on this website and refer the person (you?) to them. They (the customer) will thank you for it.0 -
professional
OK, I've re-written this a couple times to keep out the sarcasm. None of "you" are in our area. A local guy has already been contacted. I thought one of you might have some helpful insights.0 -
Locating help to solve the problem.
Ross:
I've sent an email to your initial email address. Maybe we can help.
Tom Meyer
Senior Designer/Trainer
Precision Hydronics Corp
www.precisionhydronics.com0 -
Ross.....if your connected load calculation is correct{go over it carefully three times.....did you size for disconnected radiation).....you can save a lot of money and still heat your houses.....check your load before you go further in terms of outdoor reset,etc...john
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
