short-cycling boiler
ross
ross Member Posts: 37
I know of a steam boiler that short-cycles pretty badly. I believe it is because the boiler is about twice as big as the connected load. As I recall, it is a Smith cast iron sectional with a Powerflame burner. This is a housing complex with around 16 homes. The boiler is in operation when the outside air gets below a set temp. A few years ago they tried to lower the heating bills by putting in a timing device that allows them to have the boiler be "off" for designated time periods. I don't think that this has really helped much... they end up overheating their spaces when it is on so they will be comfortable during the off times. I was thinking they could have the burner adjusted to a lower setting to try to get more even operation. How feasible is this and what kind of problems could arise by doing this?
  • Mark Wolff
    Mark Wolff Member Posts: 256
    Find A PROFESSIONAL
    on this website and refer the person (you?) to them. They (the customer) will thank you for it.
  • ross_5
    ross_5 Member Posts: 19
    professional
    OK, I've re-written this a couple times to keep out the sarcasm. None of "you" are in our area. A local guy has already been contacted. I thought one of you might have some helpful insights.
  • Tom Meyer
    Tom Meyer Member Posts: 300
    Locating help to solve the problem.
    Ross:
    I've sent an email to your initial email address. Maybe we can help.
    Tom Meyer
    Senior Designer/Trainer
    Precision Hydronics Corp
    www.precisionhydronics.com
  • john_27
    john_27 Member Posts: 195
    Ross.....if your connected load calculation is correct{go over it carefully three times.....did you size for disconnected radiation).....you can save a lot of money and still heat your houses.....check your load before you go further in terms of outdoor reset,etc...john
